Automatic update issue
Never seen before. I would try to start the installer as admin, but where is it saved?
… I found it and started per RMB and Admin rights it works.
C:\ProgramData\McNeel\McNeelUpdate\DownloadCache\
Could be nice if the automatic update would work like before. Any ideas?
let us know if this continues to be an issue.
The problem ist back. Quite frustrating, since Rhino is removed and I need to look for the manual update download. I hope it can be fixed. Good luck.
Hi Micha -
Thanks.
We see this happen once in a while but it hasn’t been possible to reliably reproduce this issue, which makes it very hard to try to fix.
Ah, ok. Only I can tell more is that Rhino 7 updates are working fine.
