Hi Brian
I have a problem installing last WIP . See teh attached Image.
When I click OK, nothing happens
Vittorio
@brian Can you help here?
Translated message reads:
The feature is located in a network resource not available
Click OK to try again or enter into the box below the path to a folder containing the installation package “rhino.msi”
Ciao Vittorio,
Something got deleted from your computer that the installer was expecting to find.
I have seen this happen when updating from an older version of Windows to Windows 10 - did you do that since the last WIP was installed?
Or, do you have a program that you use to clean up “unnecessary” things from your computer?
Not sure if it is the same problem but the topic matches: I can’t update nor install Rhino WIP.
Installed version is 6.0.17116.6371, 26.04.2017.
Update just terminates at inital stage.
When I download and install rhino_en-us_6.0.17136.10381.exe the following screen appears:
The log file: Rhino_WIP_20170518093415.txt (26.1 KB)
Help please!
@brian - Can you help?
@mikolaj - sorry I missed this before. Can you please try installing the latest WIP and send the latest log files?
@brian - Sure. I’m getting the same error code.
The log files: Rhino_WIP_20170524223539.txt (27.2 KB)
This has happened to me too. I’m sure I’ve totally mucked things up trying to fix it myself. Its getting stuck trying to remove the old version. I tried to uninstall from Control Panel, but it said there was an error and did I just want to remove Rhino WIP from the list of installed programs, so I said yes. Then I deleted the Rhino WIP folder in Program Files but it still wouldn’t install. Then I tried CCleaner to ‘clean’ the registry but that hasn’t helped neither.
BTW, I hadn’t done anything crazy between this version and the last of Rhino WIP (like run CCleaner or update windows - Creators update hasn’t appeared on this PC yet) so I don’t think I’m to blame. I did install a few Grasshopper plugins though.
Any help?Rhino_WIP_20170525111350.zip (22.4 KB)
I was feeling desperate so I deleted a bunch of registry keys in HKLM\SOFTWARE\CLASSES\Installer\Products that had to do with Rhino 6, and got the latest WIP to install after that. Hopefully I haven’t caused any problems further down the road.
@brian - Can you look into it? From what @gavinmetzler reports, I understand deleting some registry keys should solve it but perhaps you could point out which exactly are safe to be deleted.
Hi @mikolaj,
The install problem you’re seeing, and the one reported by @gavinmetzler are different. His solution is likely not going to work for you.
What happens if you first remove Rhino WIP from your computer before installing?
Sadly, there’s very little useful information in the log files you sent - please send the next ones. I hope they have something more descriptive.
Rhino_WIP_20170605211840.txt (20.8 KB)
Again, there’s really nothing here. There’s absolutely no indication about why installation is failing.
I wonder if some part of the installation is being blocked by a virus scanner?
Hey @mikolaj,
I had a look at your log, I think it may be the same problem I had, but I’m no expert!
I think these were the keys I had to delete. Obviously registry editing is dangerous, so backup and/or get help.
@gavinmetzler - many thanks, but it seems Brian was right - it works when I deactivate virus scanner.
