Unable to See Curve Print Widths in RH8?
Hi to all,
In RH7, I can see curves with Print Width = 10 by turning PrintDisplay on (or using View → Print Preview).
Under Properties/View/Display Modes/Wireframe/Objects/Curves I have Curve Widh Usage=Use Object’s widths, which I believe controls the on-screen visibility of curve print widths in Wireframe mode.
In RH8 SR24, the same settings don’t show the curve widths. Are there any other settings that affect this?
Thanks for any help!
PS:
Hi 007 -
It controls the on-screen visibility of the curve object’s width, which is gotten from that object’s linetype.
I don’t know if that means that you are setting a print width to the object or its layer. Have you set PrintDisplay to On?
Do you have a custom linetype set to the object or its layer?
Please post a .3dm file.
