Setting curve's print width bug
Hi @dale,
setting a curve’s print width in the object properties panel seems to be limited to values only present in the dropdown. Values larger than 2 revert to 2 and values not present revert to the next lower value once the curve is re-selected.
Rhino 8 WIP (8.0.22319.12305, 2022-11-15), Windows.
_
c.
I can confirm this and logged as RH-71459 Print line width cannot be set to dimensions other than listed in the dropdown
Hi Gijs, thanks for adding this to the bug tracker.
_
c.
there is other (older) topics about print width.
not sure if they ever got solved:
thanks to include it in a test / fix. - kind regards -tom
RH-71459 is fixed in the latest WIP
what about this line width issues ?
see my post above …
thanks
Your other topic is already in another thread; if we fix it, we’ll post about it there.
