In Revit 2024, I’m unable to load the R7 as R8 Rhino.Inside.Revit (RiR) plugin . I receive an error stating that RhinoInside.Revit.Native.dll cannot be loaded (see attached image). However, the plugin works fine in Revit 2025.
The .dll file is located in the 2024 add-in folder. I have already reinstalled both Revit 2024 and Rhino.Inside.Revit. I suspect I might have made a rookie mistake, as I’m just starting out with programming in C# and encountered some issues with namespaces between RevitAPI and RhinoAPI.
I couldn’t find the solution on this forum yet. Does anyone have a solution to this problem?
Thanks in advance!
Ted
