I am not able to load Rhino inside addin for Revit, I am attaching the snapshot for the same…
Can someone help me regarding this issue.
Could you confirm us you have those three files in the Rhino.Inside Revit Addin folder?
It may be installed on:
Per user: %APPDATA%\Autodesk\Revit\Addins\2020\RhinoInside.Revit
All users: %ProgramData%\Autodesk\Revit\Addins\2020\RhinoInside.Revit
You may need to update your Windows through Windows update or download it manually from here.
You need the x64 version (vc_redist.x64.exe).
Hi Kike,
I forgot to install WIP, I installed it and its just working fine.
Thanks for everything…
