Hello
Running Rhino 6 & WIP.
The UI icons seem to be regularly shifting in colour… They go black/inverse colour.
It’s random and seems like some graphics/UI issue!
Please help!
Hello
Please help!
Can you run SystemInfo in Rhino and post the results here?
Is this happening in both V6 and the WIP?
Thanks ! Yes, in both v6 & WIP:
Rhino 6 SR8 2018-8-28 (Rhino 6, 6.8.18240.20051, Git hash:master @ d037927543424e8b3ce54e46b435866178a6349c)
Licence type: Commercial, build 2018-08-28
License details: Cloud Zoo. In use by: Sach Chauhan ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: HELLO
Quadro K1100M/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 391.58)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-30-2018
Driver Version: 23.21.13.9158
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Nope… Your driver looks relatively recent, so no idea here…
Hello
I’m still having this issue in WIP.
Any ideas?
Thanks,
Hi sach - if you run ToolbarReset and restart Rhino… does that do anything to clean up?
Hi Sach,
Have you installed the Fall Windows 10 Creator update and if so have you enabled dark mode? Just curious, this looks like something has messed up the alpha channel on the button bitmaps.
That’s what I thought - alphas, but it is only some, it looks like.
Hi sach -
ok, so changing/resetting the toolbar file is unlikely to help I guess.
@pascal - no it’s doesn’t help. They turn black when i hover over and then go back randomly after a few seconds if I then hover over other areas of the screen.
@pascal
I think that I may have figured it out. It was also happening in v6. I realised that I had a few apps and multiple Chrome instances open. I closed everything and the issue disappeared… So it maybe related to my GPU resource and how it’s being used?
Thanks,
According to my experiences you are right. I observed this “black spots” in browsers when my GPU was overloaded due to many running applications
@Nosorozec
Thanks. It’s hasn’t happened since I closed the apps, so yes, it’s must be that!
