Hello
I’m having a recuring problem with how my displays look in Rhino 8. A few times over the past year I will open up rhino and everything looks grey when in Shaded mode like in the two displays on the right of the screen. Additionally the Ghosted mode will often flash all of the rainbow colors as I move around in the viewport, I’ve recently updated my Graphics software, which temporarily fixed the problem but it has reverted again and I’m not sure how to trouble shoot this again. What I have tried so far: I have all my displays reset to Default, and tried adjusting the colors but nothing has worked. I’m at a loss for what to do, any and all help would be much appreciated!
Hello @Mars1
Pls run _SystemInfo in Rhino and post back the results.
Rhino 8 SR15 2025-1-13 (Rhino 8, 8.15.25013.13001, Git hash:master @ 424331904354085c3cb84eda50bc6e3d92d470f4)
License type: Educational, build 2025-01-13
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y). OpenGL Ver: 1.1.0
Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated (slow!) graphics device with 4 adapter port(s)
Secondary graphics devices.
NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 12GB, Driver date: 6-25-2024 (M-D-Y).
- This device is not being used
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25013.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Your rtx is not being used for Rhino
See Soooo, you bought a laptop with hybrid graphics and rhino doesn't run right. READ THIS
I’d do a clean install of your nvidia driver-
install using the custom/advanced option and click the “clean install” checkbox
restart and look at tools>options>view>open gl and insure rhino is seeing your nvidia
