Hi there,
I’m having an issue where all of my icons (new and existing toolbars) are displaying incorrectly.
See attached image. Any ideas how to fix this?
Thanks!
Hi there,
Thanks!
If your graphics card (GPU) driver is older than about one year, it may be the cause of your problem. To find out how old it is, run SystemInfo command. This command will display lots of info about your computer, including:
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-29-2020
If the date is older than about one year (as shown), you should update the driver.
Hi Andrew,
I’m using an RTX3090 - with the latest driver from NVIDIA installed.
Any other ideas?
Cheers,
Please run the SystemInfo command in Rhino and paste the results here.
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 8-27-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.96
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 8-27-2021
Driver Version: 30.0.14.7196
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Users\turveyf\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21201.1426
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
Try running the pluginmanager command in Rhino and disable both Enscape and VRay. Restart Rhino and see if this makes a difference. This will help eliminate any possibility that a plugin is causing the display issue. If that doesn’t make a difference, we can try some other things.
