TXT2MTXT command
I’m not a developer but I’m wondering if some one of you had made Autocad command (TXT2MTXT) in Rhino which the selected single line text objects are replaced by one or more multiline text objects. The command maintain the text size, font, and color differences between text objects, if possible.
I think is very usefull.
Thanks in advance for your help
Hi @giobuttu
To my understanding, all Rhino Text objects are multiline.
Yes, but some dwg files (expecially those exported from Revit) have all text are single line. Txt2Mtxt are can help to merge multi single line txt (room name, space use type, sruface area, etc.) in a single multiline txt. This multiline ca easily used to do analysis in grasshopper.
