I am trying to export a .dwg or .dxf from rhino to autocad and everything comes in fine but the text is backwards.
Please help !
@pascal
Please help !
@pascal
and upside down, been messing with cplane but it doesn’t make sense to me
You may use BoxEdit for all of those texts at once.
Make negative scale factor “-1” in axis needed.
Make sure you have Independent edit mode. And around Center points.
You may also explode text (temporary) to have an idea how they will be oriented like in AutoCAD.
Yes I have that checked. still doing it
Uncheck it and then you will see that your texts are actually backwards in Rhino as well. Fix those and then re-export…
no they are not backwards when unchecked. ![]()
not sure what you mean, can you provide step by step instructions
Hi @zale_orcid .
Run BoxEdit command.
Select all the texts you need to edit.
To check them just Explode texts and you’ll see the real orientation. Then Undo to go back to Text objects, not curves.
Before Explode
Great, thanks @Screamer - I’ll look into this when I have a chance and will report back… I swear there’s something wrong with my rhino — but I’ll look at this and report back
