I just upgraded to v6 and have two super simple questions.
#1 How do I hide the dotted outline on a circle?
#2 On my wireframe Top viewport, I only see a portion of the cylinders. How do I show the complete shape?
Thanks.
Ray
Thanks.
Ray
#1
For the circle _PointsOff (F11)
Thanks, siemen. Exactly what I was looking for.
Pascal,
Yes, the isocurves option was off but turning it on didn’t change anything.
I attached the file in case it helps.
123.3dm (70.3 KB)
What you are seeing is what a cylinder looks like in wireframe: the definition circle(s) and the cylinder seam. To get more you need a different display choice.
Note: I took the word “wireframe” to mean exactly that; if the view is actually in a different mode, then I apologize.
Something is amiss here though. …
still poking.
AIW,
In v5 it used to show the complete shape.
In case it makes a difference, the two shapes in that file are circles that were extruded and not cylinders.
If I create a new circle and extrude it then the full shape shows in v6 so it seems to be a problem with opening a file that was created in v5.
Hi Raymond - yes, opening a v5 cylindrical extrusion in Rhino 6 seems to have that effect. I’ve created issue RH-53724. Thanks for reporting.
Thank you for confirming and submitting the bug report. Looking forward to the fix.
RH-53724 is fixed in the latest Service Release Candidate
