Trouble with picking surfaces
bug logged here- https://mcneel.myjetbrains.com/youtrack/issue/RH-58382
RH-58382 is fixed in the latest WIP
@phcreates fixed! just tested it- thanks for reporting!
In today’s WIP problem still exists.
Model: select.3dm (49.1 KB)
Works as expected here - much better than yesterday. I tried your file and my file from this thread, and had no problems extracting faces.
can you run the systeminfo command in rhino and post it?
System Info
Rhino 7 SR0 2020-5-12 (Public Build, 7.0.20133.11585, Git hash:master @ 80ff3fd5d5ccdf5df25139f27f24ec3de87b99b4)
License type: Edukacyjna, build 2020-05-12
License details: Cloud Zoo
Expires on: 2020-06-26
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 4-7-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.92
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-7-2020
Driver Version: 26.21.14.4292
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.0.20133.11585
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20133.11585
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20133.11585
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20133.11585
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20133.11585
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino WIP\Plug-ins\Calc.rhp “Calc”
This issue seems to persist but only when using my custom shaded modes…otherwise it works fine in the standard default shading mode.
is there an option in the custom shading menu under preferences that I’m missing for object selection of selecting visible objects only as a persistent setting?
if you reset and rebuild you custom shading modes does the problem resolve?
to test, make a copy of the custom mode, reset it to defaults then reenter your settings. If it fixes the problem, delete the original and use the new one. A lot of stuff got changed in the first few service releases and sometimes the fix is to begin anew. A hassle yes, but hopefully once rebuilt it should behave going forward.
Thank you. This worked.
Please take a look on this picking behavior, instead of picking the edge Rhino selects either completely invisible back surface or top surface. User needs to be extremely precise to select the edge.
picking edges.3dm (328.6 KB)
System Info
Rhino 7 SR7 2021-5-31 (Rhino 7, 7.7.21151.13001, Git hash:master @ 24d76fc798fa6ffd33733e5f18b034d547b87840)
License type: Edukacyjna, build 2021-05-31
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
C:\Program Files\Rhino WIP\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino WIP\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\USER\Desktop\Crayon\unpacked 1.1.1\Crayon.rhp “Crayon” 1.1.0.0
C:\Program Files\Rhino WIP\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.0\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.0\Substance.Win.rhp “SubstanceImporter” 2.0.0.0
C:\Program Files\Rhino WIP\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.7.21151.13001
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21151.13001
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21151.13001
C:\Program Files\Rhino WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.7.21151.13001
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21151.13001
C:\Program Files\Rhino WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.7.21151.13001
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21151.13001
try making your laptop monitor the main display, this won’t change anything about using your machine, only what happens to the graphics pipeline-
right click your desktop, go to display settings, then use the identifier to see which monitor is which, then select the laptop monitor and check the make this my main display. This then sets the state for the graphics pipeline and sets the external monitor as a pass through.
Id that makes no change, I’d start picking at the plugins… turn them all off then restart rhino, any change? if so, start turning them on one by one and then note any changes.
A clean install of your graphics card drivers may help if the above lends no result.
