I have a problem picking the surface in shade mode, in extract surface command it just cannot detect the surface i try to pick, to pick surface I need to change to wireframe mode, which the operation efficiency lowered.
My Rhino is Version 7 SR26
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 2-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.18
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-24-2023
Driver Version: 31.0.15.3118
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot11RhinoPlugin (55124e8a-aa81-4be8-8e12-9f452c473970)\2.0.0.0\KeyShot11RhinoPlugin\Rhino 7\KeyShot11RhinoPlugin.rhp “KeyShot11RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\RhinoResurf\RhinoResurf_r7.rhp “RhinoResurf”
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
I would first update Rhino to 7.36 and also update your video driver - it’s a year old.
If you are still having problems after that, then you can try temporarily disabling the 3 non standard plug-ins and see if that fixes it. If so re-enable them one by one to figure out which one is causing the problem.
