Trim doesn't work properly
Trim, for me only works about 95% of the time. This is what happened today. All of the lines are planar.
Start with this
Select lines to trim. The red are what I attempt to trim
Look at this result? Makes no sense. The other line will not trim at all. This happens at least a dozen times a week
What could possibly be wrong?
I end up having to split everything and then get rid of what I don’t want. Seems like if it will split it should trim
thank you for your help
Ken
Hi Ken - please post a file with the curves and an of indication what trims what.
Thanks Pascal but I already split everything and then deleted the parts I didn’t need.
I just cannot figure out why this happens
Appreciate your quick response
Ken
Hi Ken - if you can reproduce the setup so that it happens again, please Undo and save the file - post it here, or send to tech@mcneel.com, to my attention, with a link back to this topic in your comments.
