I’m having a bit of an issue with the trim tool in Rhino 7, where if I select the area at which I need to trim, it trims certain, seemingly random, segments of the curve, instead of trimming before the intersection of the curves. I’ve tried rebuilding the curve to (2,1), (showends), and (insertknot), none of which really solved the problem. Sorry if this issue is a tad insignificant. Any help would be much appreciated.
OK, took me a minute to reproduce the problem. Inside the trim command, set “Extend cutting lines” to No… then it works. See video below. Note, your wall is poorly offset, there are overlaps or gaps, but it still seems to trim correctly.
Ahh that would make alot more sense, thank you very much. Yes the offset line isnt finished because it’s meant to be a boundary for the trim. After I trimmed the curve it would be deleted after. But thank you very much once again. Sorry if it was too much trouble.
