When toggling the history command by entering it on the keyboard, the history button gets marked incorrectly …
Version 7 (7.5.21096.11002, 2021-04-06)
Thanks for the report, I’m not seeing this here so far. These are the steps I took…
Run the History command > R Enter > Enter
correct. Though I get the result as reported above – after the 1st “Enter” … ![]()
edit:
hovering the button makes the (white) text come “through the button”…
Okay, thanks for confirming. Does this happen in any file including a new blank one from a template? Can I see your SystemInfo command results as a text file too?
Yes. (Sorry for that)
sure:
Rhino 7 SR5 2021-4-6 (Rhino 7, 7.5.21096.11002, Git hash:master @ 4cd1d638a2f2d3bb193441ecfc1e54559d092807)
License type: Commercial, build 2021-04-06
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H524) (Physical RAM: 16Gb)
Mac Model Identifier: iMac18,3
Language: en
AMD Radeon Pro 580 OpenGL Engine (OpenGL ver:4.1 ATI-3.10.19)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8 GB
Graphics: Radeon Pro 580
Displays: iMac (217dpi 2x)
Graphics processors
Radeon Pro 580 (8 GB)
iMac (2560 x 1440)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
3Dconnexion: SpaceNavigator
Bluetooth devices
Broadcom: Magic Mouse 2
Broadcom: Magic Trackpad 2
Nordic Semiconductor:
Third party kernel extensions
com.3dconnexion.driver (1.1.4) 1DD89656-D184-33C7-B591-74B28B80D03F
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftFoundation.dylib
/Users/maasmeier/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp/libkeyshot_rhino_plugin.dylib
/Users/maasmeier/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp "KeyShot9RhinoPlugin" 1.0.0.0
/Users/maasmeier/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Iris.MacR5.rhp "Iris" 1.0.0.0
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 7.5.21096.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 7.5.21096.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 7.5.21096.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp "Displacement" 7.5.21096.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 7.5.21096.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp "Import_OBJ" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp "export_xaml" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp "export_OBJ" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp "Export_DAE" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp "IGES Export Plug-in" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp "Import_SVG" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp "Export_AMF" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp "Import_DST" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp "PLY - Polygon File Format Export" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp "Import_AMF" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 7.5.21096.11002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 7.5.21096.11002
Thanks, nothing much is jumping out at me from your system info. Did you try restarting your Mac? Did this just start happening for you or did you just notice it after using the History command to toggle the state? If a restart doesn’t change anything, does disabling the Keyshot plugin in Preferences > Plugins and then restarting Rhino change anything?
