I want a 100% replica of the stl format.
need it from mesh to nurbs surface or remodelling purpose so that i canchange the thickness of the surface and remove some components of the scanned stl data
No modifications made. Length X Width X Height = 135mm x 147mm x 73mm
Please find the image attached for the same
REPLY ASAP
my number is +91 9887713033
divyank.d.jain@gmail.com
Hi Divyank - there is no easy way to do this in Rhino. You’ll just need to model the object from surfaces using the mesh as a template and reference.
See also: http://www.rhino3d.com/resources/#tabs-17
