Hello all, I’m having an issue whit two super tiny naked edges which I can’t join at all. I tried many times to join them or to testRemoveAllNakedMicroLoops, but no solution found yet. If someone can give it a chance I would be very much thankful!
Yes, I just Rebuilt them to have them more smooth because it should be 3d printed. I thought it could be a good solution to do so, it is my first experience doing this sorry
Hello - do you have the originals, before rebuilding? For 3d printing you need to adjust the mesh derived from the surfaces, but surfaces are typically smoother if they are less dense anyway…
Hello - you can FitSrf at say .001 to simplify but you’ll need to re-intersect everything - it will be messy, it would be better to go back to the originals. So, for now, let’s try to fix the edges well enough to print…
@gabbserrau -I’ll send you a closed object via our upload site…but, for the future, was not a good approach - Rebuild has some good uses but this was not one of them.
Another thing, your object is small - a fraction of a millimeter overall - so if you really want to make an object that tiny you need to work at much smaller tolerances - see
