Trying to process this file for 3D printing but my slicer keeps tripping up on the naked edges. I tried shrinkwrapping in Rhino 8. It works well enough but creates a mesh that is too round and also doesn’t really fit well with the rest of the geometry in the print.
As its a fairly complicated geometry, I’d ideally like to avoid manually rebuilding as much as possible.
Dear @Brandt_Rentel
I doubt there is a reliable fast method to get correct data fast.
(maybe some mesh based approach ?
looks like you have multiple nearly parallel surfaces.
second screenshot is with a clipping plane - this shows the problematic “multi-wrapping” of the design-intent. my guess is you have to re-model most surfaces.
_MergeAllCoplanarFaces will remove a few of the problems.
