I first had this problem over a year ago. V7 would boot up with the Command Prompt window and all my panels missing.
Options Panel showed that the checkbox for the Prompt was unticked, and it would reappear (though not in the right position) when the box was ticked again. Panels will come back if reactivated in the Panels menu.
I usually use two screens but the missing panels/prompt do not appear on the extension screen, and this also happens when I am working with just one screen.
Although this initially happened after trying to port my settings over from v6 to v7, it reoccurs randomly, on average I’d say about every six weeks or so. it does not seem to be linked to updates.
Both XML settings files are dated as having been modified when I booted up.
Also, just now when I opened a new file by double-clicking it in windows explorer, the prompt/panles were gone even though the file i had up had them. When I went through Rhino’s File > Open to open the file, the panels/prompt were there.
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 12Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-26-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce MX250 (NVidia) Memory: 4GB, Driver date: 5-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.78
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-5-2022
Driver Version: 30.0.15.1278
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
That sounds very hard to troubleshoot…
If it’s enough of a nuisance that this happens, I’d rename the %AppData%\McNeel\Rhinoceros\7.0 folder to something else (e.g. “7.0-backup”) and start Rhino again. That will create a new 7.0 folder and all settings will be reset to the defaults. Then manually apply customization.
Note: you can then still run Rhino with your current settings by launching it as a different scheme.
("C:\Program Files\Rhino 7\System\Rhino.exe" /Scheme=7.0-backup)
Thanks. I’m not sure it’s enough of an annoyance to go through redoing all the customization – probably faster just to manually restore the prompt/panels every several weeks!
One relatively straightforward potential fix was to uninstall Rhino 6, but it sounds like there’s no chance of “cross-contamination” (apologies for the technically obtuse vocab) between the two versions’ settings files?
