So I am having an issue with my properties panel not showing up in the prompts at all. I tried typing properties to command bar and it wouldn’t show up. I had also looked in the toolbar plug-in setting to see if the renderer development kit and UL were on which they were, therefore I don’t know what can cause this to disconnect, unless its Enscape.
Hi Bogdan -
Please run the Rhino SystemInfo command and copy-paste the output here.
Did you try disabling Enscape and restarting Rhino?
Yes, I tried disabling and restarting Rhino, here is the system info
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Educational, build 2024-04-16
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 7-24-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.5768
Secondary graphics devices.
NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 0MB, Driver date: 8-30-2024 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.5768
Driver Date: 7-24-2024
Driver Version: 32.0.101.5768
Z-Buffer depth: 24 bits
Total Video Memory: 2097148 KB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 4.2.1.88
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.9.8389.22035
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Hi Bogdan -
Something is messed up with your display hardware. I’d recommend doing a clean install of the newest drivers for the RTX 3050 Ti and then making sure this is the GPU that the system uses for OpenGL display.
