Since updating, the materials button vanishes when switching from rhino render to Vray render. Updating the packages did not resolve this.
Properties tab|533x499
Hi Eric -
Does the button reappear when you switch back to the Rhino Render?
Hi @wim,
Could you split the last two posts into a new thread as they relate to a different topic?
Thanks
Jeremy
Hi Jeremy -
I’m not disagreeing but was hoping that the answer to my question would indicate just how much of a different topic this is. Sounds like a different category is in order but I’m not sure yet…
Posted it here as i had the same issue not loading the plugins and was assuming my issue was linked.
The button re-appears when switching back, yes.
Thanks - that sounds like a V-Ray issue then. Move to the V-Ray category.
Any solution here? Very annoying that i cannot select Vray materials in the rhino materias tab anymore.
There is no reason for the button to disappear. V-Ray no longer overrides EnableCreateMaterialButton() and EnableEditMaterialButton(). The tab button itself, is removed by Rhino for some reason, but this is the first time I ever see this case. It is certainly not a problem for all the other users.
Could you:
- report V-Ray and Rhino versions.
- possibly update both of them
- do you have any other custom plugins enabled ?
V-Ray for Rhinoceros 6 3.60.03
Build: 03 Hash: 25ae2bc Date: Jul 3 2018
V-Ray NeUI Version: 1.1.6 Build: 2024 Hash: f2540dc Date: Jul 3 2018
V-Ray Core Version: 3.60.04
V-Ray AppSDK Version: 1.24.02
Rhino: Version 7
(7.4.21078.1001, 2021-03-19)
Commercial
No changes to other plugins.
So you run V-Ray for Rhino 6 3.60.03 in Rhino 7 ?
Brave, but that is not supported.
The installer does not give you an option to install for 7, and for strong reasons
In fact I expect it crashes all the time.
V-Ray for Rhino 3.60.03 is not supported anymore either. System Requirements - V-Ray 5 for Rhino - Chaos Help
I think in the times of 3.x we still used to override EnableCreateMaterialButton(). But the main focus there was still Rhino 5
I suggest you run that particular version of V-Ray in Rhino 6
Did you try resetting the toolbars?
