When an object is grouped with a text dot label and you select the group then use the Properties palette to try to edit the contents of the text dot every keyboard stroke closes the text dot tab and goes back to the generic properties tab. So actually editing that text dot requires several trips back to the ‘A’ text dot tab to complete.
RhinoTextDotEditBug.3dm (45.8 KB)
