Text dissapears in all views
When opening an existing document that contains text, or when creating text in a new document, it seems to disappear. When I write “selText” it selects all text objects, but you cannot see them. It’s not possible to zoom in on them either. It’s not possible to select text objects by clicking and dragging. I can only see the text when I’m actively editing text height or model space scale, but the second I click enter it disappears again… It is not visible in any viewport, not layouts either.
I’ve had this problem with Rhino 7 for a long time, and I’ve tried to google it and cannot figure out what’s wrong. Hope you can help me! :slight_smile:
Hi Selma -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Commercial, build 2022-02-08
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-21-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 1-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-31-2020
Driver Version: 26.21.14.4223
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.15.22039.13001
Hei Selma -
As a first thing to try, I’d update the drivers of that GPU. Open the Notifications panel in Rhino and you should get links to the NVIDIA site where you can download the latest.
If new drivers don’t do the trick, disable V-Ray in the plug-ins page of the Rhino options and restart Rhino.
Any luck?
Mvh,
Tried doing both, no luck yet, unfortunately.
Heia -
OK - when you start a new file, do you start it from a factory-default template or do you use one that is specific for your organization? Which display mode(s) are you using in the viewports and are those display modes factory-default or are they modified?
I saw that the text was visible in all other views than wireframe, so I just restored the settings for the wireframe view, and now it is visible. Haha what simple solution. Thank you for your help!
