Text not displaying in Rhino viewport
I recently purchased Rhino 6 and installed it on a windows dedicated server. It seems to work fine except for one problem I noticed today. Grasshopper text does not display in the Rhino viewport. As I zoom in and out I can see red lines where the text should be. Rhino text doesn’t display either unless I change the wireframe viewport settings from OpenGL to windows. This change makes it so no grasshopper geometry displays.
When I create rhino text nothing appears on the screen but when I drag a selection box over the area it says that a text object is selected.
Below is the system information.
Rhino 6 SR14 2019-5-7 (Rhino 6, 6.14.19127.17141, Git hash:master @ 5b633aaa430941b76f5789a0ce3bb670ce06947a)
License type: Commercial, build 2019-05-07
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: WIN-KJOOGBJOETG
Non-hybrid graphics.
Secondary graphics devices.
Microsoft Basic Display Adapter (Unknown) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.14.19127.17141
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.14.19127.17141
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.14.19127.17141
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.14.19127.17141
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.14.19127.17141
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.14.19127.17141
Does text in Rhino itself work?
Only when I set the Pipeline to windows instead of openGL. This causes display of grasshopper geometry to stop working altogether.
Rhino isn’t seeing any sort of graphics card installed on your computer. This is why text is not showing up. Other display modes like arctic and technical also probably don’t work.
As a reminder here are the system requirements: https://www.rhino3d.com/6/system_requirements
Thank you all for your help. I’m discussing this problem with the server support team and will report back with the results.
