Text/Dimensions are Slow in Rhino 7
When I click on text or dimensions, it takes 2-3 seconds for the properties window to update. Same thing when I unselect the text. During this time I can’t do anything else… slows down my efficiency immensely. I tried making a new file with nothing in it except one text, same thing. I still have Rhino 6 installed and it is instant.
Using a new Dell XPS 17 (2020)
Thanks in advance.
Hello - please run SystemInfo in Rhino and copy/paste the results here.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Commercial, build 2020-12-08
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [39% battery remaining]
Primary display: Intel® UHD Graphics (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 9-23-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.41
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-23-2020
Driver Version: 27.21.14.5241
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
Hello - if I remember right, this has come up before and works fine if the Properties panel is not showing - is that the case for you?
Yes, that is the case for me.
Is there a solution that doesn’t include hiding the properties?
Hi Justin - Please see if getting the current SR2 release helps - I believe this was fixed.
Hi Pascal,
Unfortunately I’m fully updated and it hasn’t solved this problem. Any other ideas?
Thank you
Hi Justin - I am not sure when that fix went in - I’d try this:
Open Options > Updates and Statistics page and set Update Frequecy to ‘Release Candidate’. Then click on ‘Check now’ - I am pretty sure that will get you a build with the fix - if not, then the fix needs to be refixed…
Just did it, installed the new build and still have the problem. :frowning:
OK - let me see what I can find. As I recall, we did not see this problem, only some users did so it might be hard to track down.
Weirdly I had the same issue in Rhino 6 on my old computer. I got a new computer and when I installed Rhino 6 I didn’t have the problem. Now I have it for Rhino 7.
@JVN - just in case - can you try TestToggleSpellCheckOnAnnotationText and restart Rhino? Does that make any difference?
Tried it. It was already off, but I tried it both ways to no avail.
Thanks
Hi @JVN,
Just some dumb questions, as your problem might be related to what I’m currently experiencing:
  • which font are you using?
  • does the lag duration gets correlated with the text length (the more lines of text you have, the longer the lag lasts)?
  • does your CPU shows anormal activity during the lag? Something like this:
EDIT: @pascal, you might to have a look at the following thread, as this issue still occurs on R7.3:
Hello - @jeffoulet thanks, I’ll see if I can get someone with a bigger brain than mine to look at this.
Here, I do get a lightly larger bump in the cpu graph selecting text than something else, but it is all very small - nothing at all like what you show.
@jeffoulet , @JVN - does it make any difference what font is in the selected text?
Hi @pascal, thanks for having a look at this.
What I’ve found out on my side so far:
TestToggleSpellCheckOnAnnotationText is disabled.
  • regardless the font, the text panel always requires 0,5-1 seconds to be displayed, when an annotation is selected as nothing was selected before. This makes the user experience really frustrating:
    Switching between objects is more fluid and work as expected:
  • by standard fonts (Arial, Times New Roman etc.), it seems to be no lag. By some other fonts families, the lag also does not seem to appear for the main font (let say Encode Sans), but is present for sub-types of that family (Encode Sans Light, Encode Sans Condensed…):
  • finally, the lag length is related to the number of lines in the text object. More lines = heavier lag:
There is definitely some nasty loop somewhere…
Here is the file: text_lag.3dm (84.4 KB)
And my SystemInfo:
Rhino 7 SR3 2021-1-26 (Rhino 7, 7.3.21026.13001, Git hash:master @     33003e99b55b3e99bc54b233a1b4cfd15b4a8ab2)
License type: Commercial, build 2021-01-26
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
  Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 12-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.09
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Render version: 4.6
  Driver Date: 12-31-2020
  Driver Version: 27.21.14.6109
  Total Video Memory: 5 GB
  C:\Program Files\Rhino 6\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino6.rhp	"Karamba3DLicense"
  C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp	"bullant"	1.4.4.0
  C:\Program Files\Rhino 7\Plug-ins\Commands.rhp	"Commands"	7.3.21026.13001
  C:\Program Files\Rhino 7\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 7\Plug-ins\RPC.rhp	"RPC"
  C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp	"Rhino Labs Tools"
  C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	7.3.21026.13001
  C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	7.3.21026.13001
  C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp	"Renderer Development Kit UI"
  C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	7.3.21026.13001
  C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	7.3.21026.13001
  C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp	"Displacement"
@jeffoulet - thank you - this is exactly what we need.
Jeff, the fonts that are slow are not installed, here - are they, on your machine?
RH-62653 Text selection lags
Thanks for your patience and perseverance, y’all.
Yup, these fonts families are installed on my PC. See here for instance: Google Fonts
Each one comes with a bunch of ttf for each style:
Hi Jeff - thanks - here, if I install the fonts the lag goes away completely, so far.
