I’m running into issues with Telepathy (v1.0.0.0 or 1.0.1) in Grasshopper on ShapeDiver. Sometimes it exceeds the time limit or says “no geometry” when passing a simple box. I’m using Rhino 7. Rhino 6 is in my shapediver plan.
There seems to be an issue with Telepathy versions on Rhino 6. Could you try by removing the version you have installed (likely with the package manager) and instead unblock and copy this plugin file in your libraries folder?
In case this does not work, you might need to upgrade to a plan that includes Rhino 7 servers (I tested your definition there and it works as expected). Please consider switching your old PRO plan to a Starter plan: Pricing | ShapeDiver
