ShapeDiver Errors on loading
Hi @shapediver,
I’ve had ShapeDiver installed for 3 months.
But only yesterday Rhino started to prompt me with this on opening:
Then these when opening Grasshopper:
Which is quite “funny”, since there’s no shape diver components in my script… :face_with_raised_eyebrow:
Any ideas of why this might happen? :slight_smile:
Cheers
Edit:
+1
Many errors after yesterday’s Rhino update (I believe that it’s 8.18).
We have found incompability issues due to .NET Core versions in the latest Rhino Service Release. Please revert to version 1.23 of the plugin (and uncheck “Automatically update packages when Rhino starts”) until we work with McNeel to solve the issue.
If your definition had at some point ShapeDiver components in it, from an old version of the plugin, this might explain why you are seeing the last error. When you have reverted to 1.23, you can use the top-level ShapeDiver menu and click on the “Document > Remove payload” option.
I will update this topic once the issue with version 1.24 is fixed.
The version 1.24.1 of the ShapeDiver plugin has been released to the package manager. It should fix the issues mentioned above, while including the latest features.
Thanks for the quick response and fix !
@mathieu1
I’ve noticed the similar errors in Rhino.Inside
This first:
GH_Load_Ex_shapediver_rir.txt (7.1 KB)
then this
I have error every time i start grasshopper.
This might be due to a conflict with an old version of the plugin. Please check this article, in particular the yellow section: ShapeDiver plugin for Grasshopper
The folders are clean. I have downloaded the plugin the first time from the Package Manager.
Could you let me know which version of Rhino and the ShapeDiver plugin you are working with? Ideally, if I could get a screenshot of the other third-party libraries installed with Rhino, it could also help. It looks like there could be a conflict with another installed plugin.
Error is back with latest SD version. I had to manually downgrade to previous version (1.28.1). This error is definitely related to the latest update of Shape Diver. My Rhino 8 is up to date.
Try uninstall Shapediver, shutting down Rhino, then restarting Rhino and installing the latest version of Shapediver. In worked for me.
Please review this thread: Issues downloading from package manager
