I’ve moved this to a new topic from a 6-year-old thread.
Could you please post a model that performs like this on your system and run the Rhino SystemInfo command and copy-paste the result here?
Hello - my guess is there is one , or a few, objects that are giving the mesher a hard time - if you can isolate half the model, at a time, ClearAllMeshes, Shade, and see if you can identify the culprits or narrow it down. Feel free to post the model or send to tech@mcneel.com (if confidential) , with a link back here in your comments - it will be easier to help with the file in hand.
Hi Ivan - the object has 25,000 surfaces - it does indeed take a very long time to generate render meshes at the current file settings - and the mesh has about a million faces… Each face has to be meshed, which I guess is where the hang-up is.
It would be much more useful to have an example that is not specifically designed to be slow…
you are right and i know how much of a bad example this is when it comes to sub d use
I am conscious about that but when there is not time and when , like this case , i am driven by need to arrange a very quick pseudo reverse of an imported brep to be used for quick design of temporary jig such a technique can help me get the job done decently and quickly.
its a pity to be locked by the lack of performance , or maybe by the unnecessary high shading quality of rhino.
I wonder , being very easy to create "monsters " like the one sent to you when using subd ; being this technique a decent solution when the job need be arranged in zero time; isnt’ it time to think about adding a raw shading option to be activitated automatically when nr. of faces overcome a critic limit.
this would allow users to keep working wo being slowen down by graphic interface calculation timing.
BTW the same model is easily manageable in catia and also free cad
…there is no doubt that rhino shading mode is way better that those software but to me most important thing is not to slow donw my work flow.
I will try to adjust shading option as suggested by your amazing tech support but i think the automatic raw shading option could avoid lot of imprecations
just a message to report once again that the potentiallity of RH7 on speed modelling are somehow thwarted up by the time wasted to wait for shading update after each modification.
having a cad with incredible potential and waste minutes to stare at screen in the hope shaded view will update is getting very annoying especially when you are sharing screen with customers and you are trying to discuss how to move forward.
the only chance i have so far is working in wireframe but its such a contradditions.
Point is that , as i keep reporting , other cads ( even opesource ) despite having a very poor shading mode are allowing me to shade same geometry quickly.
I am not a programmer but i keep wondering if McNeel cannot consider that chance to add a rough shade that mimic freecad or similar mode for those running rhino in machines with limited graphic performances.
You can probably do that yourself by modifying your display mesh settings and/or your display modes. In my experience however, if you are having trouble shading a particular model, there is most often a bad object somewhere that is proving hard for Rhino to create a display mesh for.
