I downloaded the latest WIP (7.0.20021.12255, 21.01.2020) and tried to work with SubDs. Unfortunately SubDs are not shading anymore. Display mode is set to shaded but I only see wireframes.
Cheers,
Detlef
Cheers,
Detlef
Detlef
I’m not seeing this. How does it look with NURBS surfaces and/or meshes?
Hi Detlef - I take it that you have updated to the latest WIP this week and that the issue persists?
Please post the result of the Rhino SystemInfo command.
Hu Wim,
yes, I just installed the latest version and the issue is still there. Here iw the output form System Info
Rhino 7 SR0 2020-1-28 (Public Build, 7.0.20028.12435, Git hash:master @ 4af0ab49665f7b455b1dce1d17667578b00858d0)
License type: Commercial, build 2020-01-28
License details: LAN Zoo Network Node Checked Out
Expires on: 2020-03-13
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DEHER1N6100
Hybrid graphics system.
Primary display: Intel® HD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-21-2017 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M1200 (NVidia) Memory: 4GB, Driver date: 6-29-2017 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 384.77
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 6-29-2017
Driver Version: 22.21.13.8477
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.0.20028.12435
C:\Program Files\Rhino WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20028.12435
C:\Users\muelldet\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Speed Engineering Suite (619b1223-749f-4b58-b3f1-cd7cc9b56ea5)\2.0.7023.27301\Rhino 6\SpeedEngineeringSuite.rhp “Speed Engineering Suite” 2.0.7023.27301
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20028.12435
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20028.12435
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20028.12435
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino WIP\Plug-ins\import_ZPR.rhp “ZCorp Import”
C:\Program Files\Rhino WIP\Plug-ins\export_ZPR.rhp “ZCorp Export”
C:\Program Files\Rhino WIP\Plug-ins\digitize_MicroScribe.rhp “MicroScribe Digitizer”
Detlef
Hi Wim,
I found the issue. It seams like one of our RH6 Plugins is creating the issue. I unloaded it and SubDs are shading perfectly.
cheers,
Detlef
Thanks for that update, Detlef.
I see that your GPU drivers are from 2017 and updating them could perhaps be worth a shot. Then again, if you don’t need to run that plug-in that is causing this and all else works fine, you might as well leave them as they are. I’m still running the June 2018 drivers for my GeForce GTX 860M…
