I am working on a simple model and I notice that everything shows up on shaded view except for a few items that I rounded the corners using the fillet edge command. The items that I modified with the fillet edge now up as wireframe even though I am on shaded view. That’s that make any sense?
maybe the fillet goes wrong and made some errors in the render mesh. hard to tell without the file
try copying and paste the objects in a new empty file
Here is the entire Rhino file… Is a very simple, small project that I started last night… Shed v1.3dm (5.7 MB)
Thanks Diego… I did copy the entire model into a new file and so far so good… However, I notice that this has been an issue for a while and from what I can see from other posts it seems to be relatively common. I did notice this situation happening with other projects, and the fact that happens only to certain elements and not the entire model seems to me that it must be software related. If it was related to my graphics card or other hardware in my setup I would imagine that it would affect all of the objects and not just some. That’s just my take…
Hi - can you run the Rhino SystemInfo command and copy-paste the result here?
Sure thing… Here it is;
Rhino 6 SR27 2020-6-24 (Rhino 6, 6.27.20176.05001, Git hash:master @ ba2c30de00be5a8b210bc297715204e941911799)
License type: Educational, build 2020-06-24
License details: Cloud Zoo. In use by: uglygator ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-SNSRD7B
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 3-1-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 419.35
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-1-2019
Driver Version: 25.21.14.1935
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.27.20176.5001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.27.20176.5001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.27.20176.5001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.27.20176.5001
C:\Users\Ricardo\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18353.6521\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18353.6521
first thing to try is update the video driver.
I’m encountering the same issue in Rhino 7 (up to date). The problem appears to be caused, in part, by a linked block. When the linked block or layer containing the linked block is hidden, the problem stops. When the block is made visible again, the problem resumes. The problematic objects are NOT contained in the linked block, they are in the model itself.
Edit: problem remains when objects are pasted into a new file, though different objects are affected in the new file (see video)
Updated video driver, restarted PC, no change. Problem only in this file, not others that I’ve tested
Workaround for now: hide the block whenever possible… Is there a better solution?
Please see attached video (edit: does not play for me in Chrome but it will if you download and play) and SystemInfo below. 3DM files (too big for forum upload):
MODEL
LINKED BLOCK
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Commercial, build 2022-02-08
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K4200 (NVidia) Memory: 4GB, Driver date: 1-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.98
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 1-5-2022
Driver Version: 30.0.14.7298
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp "Tibidabo"
C:\Users\StevenV\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll "Enscape.Rhino7.Plugin" 0.0.21329.1712
G:\My Drive\AEDAN\SV_DesignLibrary\AA- PRESETS AND TEMPLATES\Rhino\Plugins\SafeLayout.rhp "SafeLayout" 1.1.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp "RPC"
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp "Rhino Bonus Tools"
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
C:\Users\StevenV\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp "SectionTools"
I see you only have half of the minimum VRAM for R7.
What happens if you disconnect the 2nd monitor and start the system?
Any difference?
If not, the next thing to try is to disable the plug-ins that do not ship with Rhino, restart, and see if the problem goes away.
