Hi, I’m a T-Splines beginner here. Just encountered a weird problem while going through a tutorial.
Can someone explain to me why my corners are rounded while the tutorial’s corners are sharp when extruding an edge in T-Spline edit mode?
- Ivan
you have to remove some creases ( there is a tool in the tsplines toolbar for that.
It’s actually from this tutorial on Youtube at 12:30:
When I use the extrude command it automatically smooths the corner for me. But in the tutorial, it just straight away extrudes it without a smooth corner.
@ivan.k.m.ho I think that this is because the crease system changed in V4, the video might be created with T-Splines V3, anyway if you create the caps for the extremes the issue should disappear.
@DiegoKrause I think perhaps the OP wants to retain the creases rather than remove and what @laborda wrote is correct.
If @ivan.k.m.ho what I think is correct and you want that crease then do the extrusion, select those two edges and then use the t-splines crease command.
Thought I’ve tried creasing it before, but I think I got it now. Thanks all!
Ivan
