Since yesterday I have some system freezes, always Rhino was open and I used it. But I’m not sure it’s caused by Rhino. Maybe other users got freezes too. I’m the only one?
Freeze means, that the complete screen is freezed and nothing can be done anymore, only pressing the power button.
Before it freezes, can you please run SystemInfo in V6 and post the results?
This could be a problem with a plug-in or with display drivers.
Is there anything you can do that is likely to result in a freeze?
You can also go into Task Manager, Rhino the frozen Rhino on the apps list, right-click, and choose the option to Create Dump file. That’s the content of the memory registers and can be helpful in identifying the cause of the freeze.
For now I don’t found a way to repeat the freezes. Also it’s a complete system freeze so that I can’t open the task manager anymore.
Some minutes before I got a crash during I used my email program. Two Rhino tasks was open in the background. Short before the freeze the mouse was moveable only and than all freeze.
Thank you for the hint @theoutside. I’m a little bit limited to choose drivers since for V-Ray there are recommended drivers. After the crashes started I updated to the last recommended driver but it was the same.
I tested an older Nvidia driver and an older Rhino SR, but the problem stays. I suppose so it’s Windows system or hardware problem. Since the machine was my backup system only and I’m back to my main machine, I can work again without freezes. Looks like my backup machine needs a system refresh.
