Hello, about two weeks ago my Rhino started freezing while working. When I shut it down and restart it, the file I was working on can only be opened for reading and I have to restart the whole computer. If I have multiple Rhino windows open, they all freeze. Does anyone have a similar problem and, most importantly, a solution? Thanks a lot.
Hi Vojtěch -
Please run the Rhino SystemInfo command and copy-paste its output here.
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Educational, sestavení 2025-04-10
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 10-18-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 4-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.02
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-12-2025
Driver Version: 32.0.15.7602
Z-Buffer depth: 24 bits
Total Video Memory: 6141 MB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
Quick update, rhino can only run for 30 minutes without crashing, after freezing and restarting it doesn’t communicate with the nvidia graphics card and only offers the built-in intel. So I have to restart the whole system. Then I have about 30 minutes again. I’m absolutely desperate!
Hi Vojtěch -
Just to make sure, Rhino never actually crashes but becomes completely unresponsive, right? When Rhino is in that state, please create a manual dump file and send that to us following the instructions from Manually Creating a Memory Dump (DMP File) from an Unresponsive Rhino for Windows [McNeel Wiki]
Hi Wim, thanks for the reply. Yes, that’s right, unresponsive. I found a similar thread with instructions on how to send a dump file, so I sent it on Friday.
Vojta.
Hi Vojtěch -
I was notified that the manual dump file was sent in yesterday and a developer just took a look.
Please try disabling V-Ray in the Plug-ins Manager in Rhino and then restarting the machine. Does that make a difference?
Hi Wim, no it doesnt.
Could you post your updated SystemInfo please?
Rhino 8 SR20 2025-6-6 (Rhino 8, 8.20.25157.13001, Git hash:master @ 73b00899cf43922900a763212f167c03dc6f27cc)
License type: Educational, sestavení 2025-06-06
.NET 8.0.14
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 4-16-2025 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Původní Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.20.25157.13001
Hi there, is allready some solution?
Hi @Vojtěch_Adamec,
Today, the current service release of Rhino 8 is SR22. Please update to this.
https://www.rhino3d.com/download/rhino/latest/
Also, please disable all 3rd party plug-ins (that do not ship with Rhino). You can do this using the plug-in manager (Tools > Options > Plug-ins).
I have some suspicions, based on the crash reports you’ve submitted, that the issue is caused by the VRay plug-in you are using. You might check with them about an upgrade.
– Dale
