Hi everyone,
I recently downloaded Rhino 6 in evaluation version. My problem is that Rhino freeze randomly for 30 secondes every 5 minutes more or less. As I work frequently on that software and I am planning on buying a licence, could anyone share any advice/solution ? Thanks
My config:
Intel Xeon 2,80 Ghz
Ram : 16G
GPU : Nvidia Quadro M4000
nathanletwory
(Nathan 'jesterKing' Letwory)
April 16, 2019, 11:58am
2
Please post the textual results of the Rhino command _SystemInfo
Here is the system info :
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Évaluation, version 2019-02-27
License details: Cloud Zoo.
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro M4000 (NVidia) Memory: 8GB, Driver date: 12-11-2016 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 376.33
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 12-11-2016
Driver Version: 21.21.13.7633
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
nathanletwory
April 16, 2019, 12:02pm
4
paul.burgos:
You should at least update your driver.
I was actually also interested in the loaded plug-ins, but you didn’t paste those along with the first part…
my bad :
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
I tried to update it but it said that it was the latest version… i think I have to update it manually.
nathanletwory
April 16, 2019, 12:05pm
7
If you are not using a 3D mouse, can you please try disabling
With only one Rhino instance open you can do so through Tools > Options > Plug-ins
, right-click on the 3D connexion plug-in and choos to load-protect. Then restart Rhino and see if the freezes still happen.
Please report.
It still freeze after disabling 3D mouse plugin’s protection.
I’ll try updating manually the graphic driver, i’ll come back to you after i tried.
Turns out that even with a newer driver, Rhino still freezes…
I can’t see where the problem comes from
nathanletwory
April 16, 2019, 1:22pm
11
For the record, what is the result now with the Rhino command _SystemInfo
Expires on: 2019-07-09
Primary display and OpenGL: NVIDIA Quadro M4000 (NVidia) Memory: 8GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-9-2019
Driver Version: 25.21.14.2531
Rhino plugins
nathanletwory
April 16, 2019, 1:25pm
13
You still have the 3D mouse plug-in running. Try disabling it again: make sure after Rhino restart the plug-in is actually not loaded.
It doesn’t reload when I restart Rhino, it still freezes though.
nathanletwory
April 16, 2019, 1:35pm
15
I’m guessing you’re not using anything like Duet Display?
nathanletwory
April 16, 2019, 1:38pm
17
Using Rhino 3dm files from locations that get synced with some cloud service? Dropbox, OneDrive, etc? Or on a networked drive?
Maybe the company server is creating conflict but I doubt it because other worker do have Rhino working just fine. The .3dm files are on my desktop. Could the zoo cloud licence create some issues ?
pascal
(Pascal Golay)
April 16, 2019, 3:06pm
19
Hi Paul - can you disconnect the machine from the network/internet for a few minutes and see if that makes any difference?
Hi Pascal ! During few minutes I tested without internet and it seems way better ! Strange thing though that the server is slowing down the software… I will try for a longer period to see if it’s the entire problem.
