Sweep one and sweep two rails
Good evening I am trying to make a heart but:
with “sweep one rail” getting two errors (at least) as per attached photo
With “sweep two rails” I can not continue, that is I do not get any polysurface.
I attach also the file.
Thanks for the help.
Mirco
heart rhino.3dm (6.3 MB)
you could split the surface before the sharp corners, the mirror the half to make two identical sides and make a blendsrf in between:
heart rhino_blendsrf.3dm (910.0 KB)
you can also check out Plugin Update v1.1.0: Pipe Corner Clean
Thank you very much I’ll try
Thank you again, but if the heart rings are two and twisted together how can I fix it?
I mean I can not do that.
thank you. I enclose rhino file
heart rhino.3dm (14.8 MB)
Mirco
Hi Mirco -
Why not? I’m not sure I follow - ExtractSrf the surface, cut it up and delete the self intersection, BlendSrf to fill the gap and then Join it all up again -
Thank you Pascal, I’m going to try later today. You are a very helpful source!!! Thanksssss,. Mirco
Dear Pascal I have tried to ExtractSrf but it does not work.
So I have tried ExtractWireframe (pict.1), I cut and delate self-intersection and made BlendSrf (pict.2) and it does not come: you can see in the prospective view
However. Plus my pop up box i can not see: “interior shapes” which, besides, you click. thank you for you help
Hello - use Split > Isocurve (Direction=V) on that surface after extracting it.
I have now made a major cut and then used the command blendsrf, it seem a bit better but I’m not convinced. Beside I was not able to follow your indications. Plus the curbe is less pronounced while I wanted a more evident curvature. Thank you
Hello - does this help at all?
Use the ‘Natural’ setting when initially aligning the blend.
Thank you Pascal, I’ll try later today!:grinning:
I did it!!! Thank youuooooo so much
