Plugin Update v1.1.0: Pipe Corner Clean
v 1.1.0 Update: now you can change tracks’ minimal radius.
  1. Detect self-intersecting corners.
  2. Rearrange ribs and construct a clean surface.
  3. Working for both normal and variable pipes.
Note: pipe rail must open and planar. After greate a clean pipe, you can map it to space.
The component can be found under Surface → Freeform → Pipe Corner Clean
PipeCornerClean.gha (19.5 KB)
PipeCornerClean_Example_v1.1.0.zip (197.8 KB)
Great !!
