Wim,
Attached is a simple .3dm file that demonstrates the issue as requested.
I used an A2 paper size to print the 2 objects close together. Do not select the left hand object to print.
What I found was that with the TEXT layer turned off, Rhino PDF works correctly, but if the TEXT layer is turned on, it causes Rhino PDF to include some hidden artifacts that prevent Inkscape from trimming the image down to the true minimum size. Something is included in the upper left corner.
The issue is caused by the TEXT layer, even though it is not in the print area, nor does selecting all with just the TEXT layer visible show any objects in the print area.
Rhino PDF created files with and without the TEXT layer attached.
Rhino PDF Test - No Text.pdf (18.1 KB)
Rhino PDF Test.pdf (37.5 KB)
Rhino PDF Test.3dm (3.2 MB)
System info below.
Rhino 7 SR13 2021-12-14 (Rhino 7, 7.13.21348.13001, Git hash:master @ 7696723f74a63695b3c372a89110c0ca8c78b890)
License type: Commercial, build 2021-12-14
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 12Gb)
Primary display and OpenGL: Intel(R) Iris(R) Plus Graphics (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9316
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9316
Driver Date: 2-18-2021
Driver Version: 27.20.100.9316
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.13.21348.13001
