I’m stuck with a small problem. I’m making a topten sparring helmet and i need to chamfer a surface BUT the chamfer needs to flow over into another surface (so that the chamfer disappears). I simply can’t come up with the solution, i know it’s supposed to be simple and logic, but i’m new to this.
You have a polysurface lying on top of the one you are trying to chamfer. Remove it or move it to another layer and switch that layer off then fillet edge (it worked fine with a value of 1)
oooh thanks a lot! that did it! I have a chamfer (value 8) right now, but do you know how i can blend the chamfered surface with the helmet surface? I started by duplicating the edge > pipe > helmet surface & chamfered surface splitting with pipe> delete the splitted surfaces,> surfaceblend them together. But it seems not to work, i’ve used this method a lot of times before, why won’t it work now?
Anyways thanks again for the chamfer-problem
PS: Does anyone know what “…Invalid input. Nothing done…” means? I just ran into this problem
and it really has no reason to occur. I was just chamfering this, chamfering that,… after my 3rd chamfer, the error appeared, and it was on exactly the same object/surface than the previous 2 times?
What to do about it? :s
I didn’t have any problems chamfering the holes (used a value of 2) but had to fiddle it a bit around the lower ear pieces. I think you are going to encounter problems blending the surfaces around the tight curve of the chin parts. If you use pipe its likely to intersect itself here. TOP1044 003test.3dm (6.0 MB)
