Subset of objects does not move with everything else
So this one is a bit hard to describe, but the result is I have a small subset of objects, on their own layer, that jump back to their original location if I try to move them with everything else.
I have a scene as follows: 13 controls, 1015 curves, 28 surfaces, 685 polysurfaces, 336 extrusions, and 379 meshes. I’m trying to recenter the entire thing. I make sure all layers are unlocked, all hidden objects are visible, and I select all. Then I drag everything to the new location. Everything but this small subset of objects moves. After watching it close up, I realized that the objects in question actually DO move with the other objects, but when I release the mouse drag, they “snap” back to their original position.
Here’s the thing, I can select them as a group, or individually and move them just fine. The layer they are on is not locked. Has anyone seen this before? Is it possible to restrict objects movements like this or did I accidentally lock something? I have worked around the issue, I’ve just never seen anything like it.
Hi Keith -
We’ll need the 3dm file to see if we can figure out what’s going on there…
I would prefer not to share the file. It’s large and I really just don’t want to put my files up on a forum. As I mentioned, I have worked around the problem, I’m just curious if anyone has seen this before.
I have made a few small discoveries, though.
The file has 45 layers. One of those layers is called “Junk”. I usually keep it hidden, and I just put old version of objects on that layer that I may or may not need later. This layer is visible during the move, because I’m literally moving everything to the center.
The parts that do not move are on a separate layer called “Damaged Slats” They are the only things on that layer.
If I lock or hide the junk layer, everything else moves fine, including the parts on the “Damaged Slats” layer. if “Junk” is displayed and selectable, the objects in question on “Damaged Slats” do not move.
Here’s the even weirder part, if I move any other parts to the “Damaged Slats” layer, they STILL move with the rest of the parts. They are NOT stuck like the main parts on that layer.
I almost suspect that these objects are somehow locked at the object level, but even that doesn’t make sense because I can still move those objects individually or as a group, I just can’t move them WITH everything else.
Again, as I said I have worked around the issue, I’ve just never seen this before, and I have been using Rhino for a long time. Just curious.
Hi @Keith1
Did you accidentally use history on those objects?
If so you might want to try…
'_SelObjectsWithHistory
and then use historypurge on those objects.
Or are they accidentally part of a group? Use ! _RemoveFromGroup on those objects.
Or are they part of a block? Explode and then should be ok if they are part of a block.
RM
Hi @3dsynergy thanks for the suggestions. ‘_SelObjectsWithHistory reported “No objects added to selection” however, !_RemoveFromGroup actually worked. I am unsure how they ended up in a group, or if they were actually in a group, as it didn’t report anything back or say they were removed from any group, but they are movable with everything else now.
