I don’t know why these issues keep happening. The group objects will get ungroup after I move them. And the object layer will change to the default layer if I use the move command. It happens both in Rhino 6 and 7. Not sure it’s some setting or what… Very annoying…
I’m wondering if anyone else gets the same issue.
Hi -
I’m not seeing that here, no. Please run the Rhino SystemInfo
command and copy-paste the result here. Also, please post a simple file and clear instructions on how to reproduce that behavior.
model 1.3dm (1.8 MB)
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Commercial, build 2021-09-13
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display and OpenGL: NVIDIA Quadro P3200 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 11-20-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.66
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 7-8-2020 (M-D-Y).
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-20-2020
Driver Version: 27.21.14.5266
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21061.1132
C:\Users\jiewei.jian\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Marmot (b9b3c836-5b53-4f93-b359-e64bdf2a159b)\6.0.0.0\Marmot.rhp “Marmot” 6.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
I grouped the objects first then move the group. Then the group just gets ungroup.
Also, after I assign objects on a specific layer, then I move them. The objects will get changed on the default layer.
Hello - please disable ‘Marmot’ & ‘Enscape’ in Options > Plug-ins page, and then close Rhino and reopen it - is there any change in behavior?
It’s working when I disable Marmot! I’m very appreciative for your help, Pascal
