Objects not selected move in opposite direction
Strange issue. When moving a selection of objects (crvs, hatches, text, leaders), a different set of unselected objects move in the opposite direction. This happens with both the gumball and move commands. Bug? Any ideas?
261026_Bug_Move.3dm (485.9 KB)
Maybe you can upload the file?
Hi @Ben_Erickson
That’s because you have history on those objects. It looks like you copied or mirrored those objects with history on.
If you select those objects and run the command “historypurge” and purge them of history, then they won’t move along with the other objects.
RM
Ah that’s it, thanks!
