SubD Soft transform visual indicator error with vertices
Hello ! When I am trying to soft transform a Subd in Rhino 7, I am unable to have a visual spherical indicator for radius with vertices. However, I do get it when going with Subd edges or faces. I am not able to understand the problem here. Can someone help me with this…?
Thanks in advance!!
what is that?
Can you attach some picture? It’s unclear.
Here are the snapshots for your reference. I am able to see this sphere as a visual indicator of the radius I am allowed to set for SubD soft transform. But I am unable see it with vertices.
Working.
007
yes, it is supposed to work. That is why I was asking. What may be the reason for this to not work in my case…?
sometimes it helps,
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/toolbarreset.htm?Highlight=%20ToolbarReset
Can you post your system info?
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13001, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Educational, build 2023-02-01
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [58% battery remaining] ~48 minutes left
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1060 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 2-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.18
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-24-2023
Driver Version: 31.0.15.3118
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\Dell\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin” 0.0.22353.1023
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.27.23032.13001
hey inju, I tried resetting my toolbar, but somehow it didn’t work, still facing the issue.
try upgrading to Rhino 7 SR28.
Looks like it doesn’t work when in box-mode. I’m getting only a soft transform sphere in Smooth mode. @priyesh41098 @inju can you confirm this behavior?
RH-73673 SoftTransform command gives no radius preview sphere when in box mode
Doesn’t work.
If you look at his screenshots he and in the Smooth mode does not work.
This worked! Thank you so much @inju…!!!
