Help: Soft transform is not working
It works well on my computer. (I use Rhino 7.11.) Maybe you do not know how to use it? The SoftTransform command has no effect on Rhino objects - its sole purpose is editing/changing Rhino sub-objects (vertices, edges, faces, and control points). Read my post about the SoftTransform command: Rhino 8 Development - #79 by andrew.nowicki
SoftTransform documentation is here:
Hi all,
Try to use soft transform both with mesh and SubD but I can’t select geometry then…
Same happen with WIP
Anybody has this issue?
Thx
hi @Toto to set the radius interactively, preselect one or more faces, edges, or vertices of a meh/subd and then run SoftTransform. Does that work for you?
Hi
Tried several times, with mesh and SubD, nothing just happen.
Had the same result with another workstation
Same problem with primitive mesh/SubD
Tought it was a disable fonction?but seems not?
Thx for reply
in that case, pls run _SystemInfo and post back the results.
Here it is
Rhino 7 SR31 2023-6-15 (Rhino 7, 7.31.23166.15001, Git hash:master @ 850d276b2d59d7e51843939e4cf674b356bcd354)
License type: Commerciale, build 2023-06-15
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 4-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2023
Driver Version: 31.0.15.3161
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Users\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\1.6.1.0\bullant.rhp “bullant” 1.6.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\export_OBJ.rhp “export_OBJ” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp “MeshCommands” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\import_STL.rhp “STL Import”
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 7\Plug-ins\import_OBJ.rhp “Import_OBJ” 7.31.23166.15001
Hi
Did a try with my co-worker computer, same result.
hi @Toto I am wondering if you are running the tool the same way as I am doing, because I don’t see anything suspicious in your systeminfo. Can you make a short (fullscreen) video to show what you are seeing?
Sure, hummm making a video…
Any advices welcome too :confused:
something like this can be done quickly with Windows Snipping tool:
OK ok my bad, maybe I’m getting old maybe I’m tired, or both.
Works fine, sorry for disturbance
Thx
good to hear :slight_smile:
I am having trouble with it not curving or rounding out
Sorry but soft move is not working in vertical position for me in rhino 8.
Rhino 8 SR21 2025-6-24 (Rhino 8, 8.21.25175.17001, Git hash:master @ 1f082fac999ac242fff42f11f5c509a486d3df9c)
License type: Commercial, build 2025-06-24
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Primary display and OpenGL: NVIDIA T400 4GB (NVidia) Memory: 4GB, Driver date: 12-31-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 571.59
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 12-31-2024
Driver Version: 32.0.15.7159
Total Video Memory: 4 GB
C:\Users\jnavarro\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.23.2.16657
C:\Users\jnavarro\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\DOCOpalette\8.0.0-test.4\net7.0\DOCOpalette.rhp “DOCOpalette” 7.0.0.30
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\jnavarro\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PlanFinder\1.2.11\PlanFinderRhino8.rhp “PlanFinderRhino8” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\QuadRemesh\QuadRemesh.rhp “QuadRemesh” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.21.25175.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.21.25175.17001
Can you clarify what this means with a file/screenshot?
I’m trying to move and click in vertical position but the command just stops.
This is what I am seeing. Btw this is the command SoftMove, not SoftTransform
Yes, i use the command softmove, but just when I’m generating the radius and I hit click, the command ends. I’ll try to replicate this example (or just upload it plis) and see if it works.
