Rhino SubD, Toggle display between Flat to Smooth problems
Hi, Can anyone help me with this issue when working with Sub D objects? When I hit the Tab key to toggle between ‘Flat’ and ‘Smooth’, nothing visually changes to the sub d object. The only thing that changes when in ‘Flat’ mode is when I select an edge, Rhino does this…
Hi Simon -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Evaluation, build 2021-06-09
License details: Stand-Alone
Expires on: 2021-09-30
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 7.9Gb)
Primary display and OpenGL: Intel(R) HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 5-19-2016
Driver Version: 9.17.10.4459
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 2108 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
-Simon
Hi Simon - this is unlikely to work well with Rhino 7 I’m afraid - at the very least I would try to find drivers that are newer than 2016, though I deo not have too high hopes that you will find them.
Hi am also having the same issue and my computer is brand new. Below is the SystemInfo if anyone is able to help! Thank you!
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Educational Lab License, build 2022-01-10
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Trigger 6 External Graphics (Magic Control Technology Corp.) Memory: 0MB, Driver date: 11-12-2021 (M-D-Y).
> External USB display device with 2 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Primary OpenGL: GDI Generic: Microsoft Corporation. OpenGL Ver: 1.1.0
> No graphics device is being used for OpenGL
Secondary graphics devices.
NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 4-21-2021 (M-D-Y).
- This device is not being used
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-24-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
The “Main Display” is conncected to an external USB display port device, which is preventing the
proper video drivers from being loaded by Windows.
  • Recommended:
    • Use Windows’ Display Settings to configure the laptop screen as the “Main Display”.
    • Or, unplug a monitor and plug it into a built-in video port (HDMI/DP) on the laptop.
      Then use Windows’ Display Settings to configure that monitor to be the “Main Display”.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Render version: 0.0
Driver Date: 6-24-2021
Driver Version: 27.20.100.9749
Total Video Memory: 1 GB
C:\Users\thoyo\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21349.1646
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
I switched the graphics card for Rhino from NVIDIA 3060 to the Intel UHD Graphics and that did the trick; its working now. Thank you!
How did u switch the graphics?
Hi -
Which problem are you trying to solve?
The same problem as Simon, my Sub D model does not toggle between smooth and flat model. It shows it on the command display both the model does not physically change.
Hi -
Hello, I have read the above information, as I am having this same issue. Can you please tell me what I specifically need to change to fix this issue. My systeminfo is as follows:
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09001, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Commercial, build 2023-10-31
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4070 (NVidia) Memory: 12GB, Driver date: 4-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.61
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 9-2-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2023
Driver Version: 31.0.15.3161
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Gemvision\MatrixGold\MatrixGoldRenderPlugin\MatrixGoldRenderPlugin.rhp “MatrixGoldRenderPlugin” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23304.9001
Hi -
Please update Rhino to at least SR10, which is the current stable version.
If that doesn’t help, please describe the issue that you are having and upload a 3dm file that we can use to troubleshoot.
Hi, i have the same problem, when i hit tab inthe comands bar it shows thai it changed from flat to smooth but nothing seems to change
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Educational Lab License, build 2024-10-08
Windows 11 (10.0.22635 SR0.0) or greater (Physical RAM: 8GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-13-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 6-28-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.13
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-28-2024
Driver Version: 32.0.15.5613
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
Hi Maria -
Thank you for the SystemInfo data. That looks fine.
Now please post a 3dm file that shows this behavior.
smooth doesnt work.3dm (97.5 KB)
here :slight_smile:
Your object is a mesh.
You can turn it into a SubD with the command _ToSubD
