SubD Material and SubdLoft
Hello, I have 2 questions. 1. After SubDLoft(ing) the two parts I’ve made, I’m unable to assign different materials for each one of them. Is there any way to make it happen? 2. Is the command QuadRemesh the best option to smooth a Subd surface?
Appreciate it!
Kiarash
Separate selections should allow separate materials. If your two separate SubD surfaces select as one (and they are not grouped), use the Explode command to make them two separate selections.
QuadRemesh will make a new mesh or SubD which can serve to smooth a model but you could also use the Smooth command on the whole SubD or sub-object selections within it.
Very helpful, it worked well. Appreciate it!
