Hello, I created a SubD surface from RhinoVault2 through QuadRemesh.
And now I want to modify this SubD surface into a less bumpy surface with creases, like the image below. I guess I can redo the QuadRemesh with less counts, but then I loose those creases. Any tips?
theoutside
(Kyle Houchens - McNeel and Assoc. )
#2
I rebuild it using your model as reference. You essentially have a few flat surfaces that join at a crease. You can build this model with very few faces. I’d start with something like this.
Well I can surely create that vault with few surfaces if I didnt have the middle part. I have a complex geometry going on in the middle, which I cannot build manually. So instead of building from scratch, I need to modify the existing 3d model. Any tips for that?
