I am just learning to work with SubD. I learned very quickly to use Ctrl + Shift to select edges, vertexes, faces. I can select vertex and edges with no problem but when I Ctrl+ Shift + Click the middle of a face I get nothing.
I tried SubDFaceVertexToggle command.
Also SelectionFilterFaces command.
Im not sure what I am doing wrong.
I have installed Version 7.4.21067
Hi - could you please run the Rhino SystemInfo command and copy-paste the result here?
And, just making sure, which display mode is your viewport in?
