I have an issue with sub selection of subd faces with Ctrl+Shift+left mouse click in shaded mode.
But works with click and drag, and is normal in all other modes to select only with a click.
Hi -
Can you provide a file that behaves like that on your system? Also, please check if you have modified the default Shaded display mode.
subd_shaded.3dm (697.7 KB)
Hi -
There are several objects in that file. Does this happen with all of them?
Have you modified the display mode?
Please run the Rhino SystemInfo command and copy-paste the result here.
